Daihatsu Applause A101 - Documenting as much as I can
== Headunit Replacement ==
1. Remove the ashtray by pressing down on the top of it and pulling it out of the way. Behind it there is a single screw, remove it.
2. From the bottom of the surrounding trim, pull up gently until it unclips then slowly work the top clips out. Do not pull hard as the cigarette lighter and (if installed) the ashtray light will be connected and damage could be done.
3. Optional step, Remove the cigarette lighter to make working in the area easier. This is done by either removing the black pocket below the headunit and disconnecting or disconnecting the white plug on the top of the cigarette lighter and then unscrew the cigarette lighter into its individual parts, then the trim should pull away easy.
